Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Remove the two silver 17.45mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver. Remove the two bronze 13.25mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver. Slide the cartridge tray toward you, away from the 72-PIN connector, and off the motherboard assembly.
  • Remove the two silver 17.45mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
  • Remove the two bronze 13.25mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
  • Slide the cartridge tray toward you, away from the 72-PIN connector, and off the motherboard assembly.
Insérez ici votre traduction
