Aller au contenu principal
Canon PowerShot SD200 LCD Screen Replacement
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
Canon PowerShot SD200 LCD Screen Replacement: étape 0, image 1 de 2 Canon PowerShot SD200 LCD Screen Replacement: étape 0, image 2 de 2
  • Hold the camera at an angle to locate the small blue ZIF connector on the back side of the motherboard and next to the LCD screen.
  • Use the flat end of the spudger to flip up the tab of the blue ZIF connector. Slide the ribbon cable out.
  • Once the ribbon is removed, the LCD screen can be rotated away from its initial position to reveal more screws underneath.
  • Do not pull the LCD screen out or rotate past 180 degrees away from its initial position, or else you will damage the remaining ribbon that holds the LCD sceen in place.
Insérez ici votre traduction
