Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 3
Étape 3
Adjust seat to it's most forward position. Look for a stud with a plastic protection cap.  Remove the cap with a screwdriver. Using an 18mm wrench or socket (if space allows) remove the bolt from the stud.  On my bench seat there were only two studs/bolts.  Other style seats will have more. Lift seat off studs and position seat forward of studs. Adjust seat to it's most forward position. Look for a stud with a plastic protection cap.  Remove the cap with a screwdriver. Using an 18mm wrench or socket (if space allows) remove the bolt from the stud.  On my bench seat there were only two studs/bolts.  Other style seats will have more. Lift seat off studs and position seat forward of studs. Adjust seat to it's most forward position. Look for a stud with a plastic protection cap.  Remove the cap with a screwdriver. Using an 18mm wrench or socket (if space allows) remove the bolt from the stud.  On my bench seat there were only two studs/bolts.  Other style seats will have more. Lift seat off studs and position seat forward of studs.
  • Adjust seat to it's most forward position. Look for a stud with a plastic protection cap. Remove the cap with a screwdriver. Using an 18mm wrench or socket (if space allows) remove the bolt from the stud. On my bench seat there were only two studs/bolts. Other style seats will have more. Lift seat off studs and position seat forward of studs.
Insérez ici votre traduction
