Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 7
Étape 7
Next, if your truck was only using the outter body holes you will need to locate the two close to the transmission tunnel.  You can press your finger in the center and locate the opening.  Take a razor knife and gently cut an X over the hole.  Gently remove each of the triangle shaped tabs exposing the additional hole.  Repeat on opposite side. Next, if your truck was only using the outter body holes you will need to locate the two close to the transmission tunnel.  You can press your finger in the center and locate the opening.  Take a razor knife and gently cut an X over the hole.  Gently remove each of the triangle shaped tabs exposing the additional hole.  Repeat on opposite side. Next, if your truck was only using the outter body holes you will need to locate the two close to the transmission tunnel.  You can press your finger in the center and locate the opening.  Take a razor knife and gently cut an X over the hole.  Gently remove each of the triangle shaped tabs exposing the additional hole.  Repeat on opposite side.
  • Next, if your truck was only using the outter body holes you will need to locate the two close to the transmission tunnel. You can press your finger in the center and locate the opening. Take a razor knife and gently cut an X over the hole. Gently remove each of the triangle shaped tabs exposing the additional hole. Repeat on opposite side.
Insérez ici votre traduction
