Aller au contenu principal
Canon Powershot ELPH 100 HS Outer Case Replacement
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
Canon Powershot ELPH 100 HS Outer Case Replacement: étape 0, image 1 de 2 Canon Powershot ELPH 100 HS Outer Case Replacement: étape 0, image 2 de 2
  • Use the Philips #00 screwdriver to pry open the charging port cover.
  • Once you pry open the charging port cover, rotate the cover so that you have access to the screw underneath. Which is seen in the next image.
  • Remove both 3.1 mm screws using the Phillips #00 screwdriver.
  • The image still shows the screw from step 3 in place.
Insérez ici votre traduction
