Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 9 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
Use a plastic tool or your fingernails to carefully disconnect the orange headphone jack cable. Be sure to pull  straight up on the connector, not the cable itself.
  • Use a plastic tool or your fingernails to carefully disconnect the orange headphone jack cable. Be sure to pull straight up on the connector, not the cable itself.
  • This ribbon cable is very fragile. If you are replacing the battery, you can choose to skip this step and keep the headphone jack connected to the motherboard. Prop and tape the rear case against a box to keep it in place. Be very careful not to strain the fragile headphone jack cable as you work.
Utilisez un outil en plastique ou vos ongles pour débrancher la nappe orange de la prise casque. Assurez-vous de soulever le connecteur et non la nappe même.
[* black] Use a plastic tool or your fingernails to carefully disconnect the orange headphone jack cable. Be sure to pull straight up on the connector, not the cable itself.
[* icon_note] This ribbon cable is very fragile. If you are replacing the battery, you can choose to skip this step and keep the headphone jack connected to the motherboard. Prop and tape the rear case against a box to keep it in place. Be very careful not to strain the fragile headphone jack cable as you work.
