Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 3
Étape 3
Before you remove the battery, note which side faces up (+ or -). You should install your replacement the same way.
  • Before you remove the battery, note which side faces up (+ or -). You should install your replacement the same way.
  • Remove the battery.
  • Your key may contain either a CR1616 or CR1620 battery. In some cases either type will work, but for best results, replace it with the same kind of battery that originally came with your key.
  • Install your matching new battery in the same orientation as the original.
Retirez la pile usagée.
Insérez à la place une nouvelle pile CR1616, en plaçant le signe '+' de la pile vers le haut.
