Aller au contenu principal
Anglais
Français
Traduction de l’étape 2
Étape 2
Turn the laptop over so that the battery is towards you. Locate the modem and ethernet card bay. Remove the two 5.3mm cover screws.
  • Turn the laptop over so that the battery is towards you.
  • Locate the modem and ethernet card bay.
  • Remove the two 5.3mm cover screws.
  • Gently lift the cover.
Retourner l'ordinateur portable de sorte à ce que la batterie soit en face de vous.
Localiser la baie du modem et de la carte Ethernet.
Retirez les deux vis du cache de 5,3 mm.
Soulevez doucement le couvercle.
