Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 6 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Turn the Jambox upside down. Peel the indicated rubber tabs off, using a plastic opening tool if necessary. You may want to only take the tabs half way off to avoid re-gluing when reassembling. Remove the three T6, 7.0 mm screws under each rubber tab.
  • Turn the Jambox upside down. Peel the indicated rubber tabs off, using a plastic opening tool if necessary.
  • You may want to only take the tabs half way off to avoid re-gluing when reassembling.
  • Remove the three T6, 7.0 mm screws under each rubber tab.
  • Because the screws are a different length, set the screws aside.
Insérez ici votre traduction
