Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 18
Étape 18
On the left we see a row of dark coupling caps—probably in parallel. The tiny, light-colored dots within are invading microorganisms more of those little soldering voids, a remnant of the manufacturing process. There is a relatively vast amount of brains in the charger. It probably understands the charging profile of the battery—so the watch doesn't have to. Cha-ching—space savings! Up top, we spot a large BGA (ball grid array) which probably denotes the presence of a power management IC.
  • On the left we see a row of dark coupling caps—probably in parallel. The tiny, light-colored dots within are invading microorganisms more of those little soldering voids, a remnant of the manufacturing process.
  • There is a relatively vast amount of brains in the charger. It probably understands the charging profile of the battery—so the watch doesn't have to. Cha-ching—space savings!
  • Up top, we spot a large BGA (ball grid array) which probably denotes the presence of a power management IC.
  • While the board is relatively complex, it only appears to be one layer, with no components on the bottom of the board (which makes sense because it needs to lay flat and charge).
  • With close inspection we spot a littler resistor network.
  • Each filament in the network connects different points with a different resistor.
  • One-layer PCB power management—probably no more than 0.031 inch thick.
Insérez ici votre traduction
