Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Unplug the computer from the power supply before any maintenance or disassembly.
  • Unplug the computer from the power supply before any maintenance or disassembly.
  • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
  • These screws can usually be removed by hand.
  • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
Retirez les deux vis Phillips #2 de 5 mm situées à l'arrière du boîtier de l'ordinateur.
Ces vis peuvent être dévissées à la main.
-[* red] Remove the two Phillips #2 head 5mm screws from the back side of the computer case.
-[* icon_note] These screws can be removed by hand.
+[* icon_caution] Unplug the computer from the power supply before any maintenance or disassembly.
+[* black] Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
+[* icon_note] These screws can usually be removed by hand.
+[* icon_note] Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
