Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Lay down the display with screen side up. Since the display is able to be tilted up and down, we found it useful to prop up the screen up with a styrofoam block in between the screen and the base. Place the two suction cups on both sides of the top of the screen and make sure to lock them in place.
  • Lay down the display with screen side up.
  • Since the display is able to be tilted up and down, we found it useful to prop up the screen up with a styrofoam block in between the screen and the base.
  • Place the two suction cups on both sides of the top of the screen and make sure to lock them in place.
  • The glass screen is connected to the rest of the display by small magnets. Lift slowly and the screen will come right off.
Couchez l'écran avec l'écran vers le haut.
Comme l’affichage peut être incliné de haut en bas, nous avons jugé utile de maintenir l’écran en place avec un bloc de polystyrène placé entre l’écran et la base.
Placez les deux ventouses des deux côtés du haut de l’écran et assurez-vous de les verrouiller.
L'écran en verre à relier au reste de l'affichage par de petits aimants. Soulevez lentement et l'écran va se détacher.
[* black] Lay down the display with screen side up.
[* icon_note] Since the display is able to be tilted up and down, we found it useful to prop up the screen up with a styrofoam block in between the screen and the base.
[* black] Place the two suction cups on both sides of the top of the screen and make sure to lock them in place.
-[* black] The glass screen to connected to the rest of the display by small magnets. Lift slowly and the screen will come right off.
+[* black] The glass screen is connected to the rest of the display by small magnets. Lift slowly and the screen will come right off.
