Aller au contenu principal
Anglais
Français
Traduction de l’étape 3
Étape 3
Carefully remove the back cover using the plastic opening tool against the grooves along the sides of the iPAQ. At this point, a yellow ribbon will be connecting both the front and back panels of the device. Carefully use the plastic opening tool to detach the ribbon from the connector pins.
  • Carefully remove the back cover using the plastic opening tool against the grooves along the sides of the iPAQ.
  • At this point, a yellow ribbon will be connecting both the front and back panels of the device. Carefully use the plastic opening tool to detach the ribbon from the connector pins.
Insérez ici votre traduction
