Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Unplug the computer from the power supply before any maintenance or disassembly.
  • Unplug the computer from the power supply before any maintenance or disassembly.
  • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
  • These screws can usually be removed by hand.
  • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
Retirez les deux vis Phillips #2 de 5 mm situées à l'arrière du boîtier de l'ordinateur.
Ces vis peuvent être dévissées à la main.
[* redicon_caution] Unplug the computer from the power supply before any maintenance or disassembly.
[* black
] Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
[* icon_note] These screws can usually be removed by hand.
[* icon_note] Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
[* black
