Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove. If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
  • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
  • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
Puis retirez le panneau latéral du boîtier de l'ordinateur pour pouvoir accéder à l'intérieur.
Si un ventilateur est monté sur le panneau latéral, assurez-vous de débrancher le câble avant de retirer complètement le panneau.
[* black] Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
[* icon_caution] If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
