Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Remove the plastic cover with your hands. There is no need to force off the plastic cover. The plastic cover should be much easier to remove than the rubber cover.
  • Remove the plastic cover with your hands.
  • There is no need to force off the plastic cover. The plastic cover should be much easier to remove than the rubber cover.
Retirez le couvercle en plastique avec vos mains. Le couvercle en plastique devrait être beaucoup plus facile à retirer que le couvercle en caoutchouc. Il n'est pas nécessaire de le forcer.
[* black] Remove the plastic cover with your hands.
[* icon_note] There is no need to force off the plastic cover.
The plastic cover should be much easier to remove than the rubber cover. There is no need to force it off.
