Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
Unscrew the eight 15 mm T10 Torx screws from the housing The screw hole located nearest the battery port is deep and small. Most screwdrivers with replaceable bits will not fit into the hole. Instead, use a conventional screwdriver that fits.
  • Unscrew the eight 15 mm T10 Torx screws from the housing
  • The screw hole located nearest the battery port is deep and small. Most screwdrivers with replaceable bits will not fit into the hole. Instead, use a conventional screwdriver that fits.
Dévisser les huit vis Torx T10 de 15 mm du boîtier
Le trou de vis situé le plus près du logement de la batterie est profond et petit. La plupart des tournevis à embout remplaçable ne s'insèrent pas dans le trou. Utilisez plutôt un tournevis classique qui s'adapte.
[* redblack] Unscrew the eight 15 mm T10 Torx screws from the housing
[* icon_note] The screw hole located nearest the battery port is deep and small. Most screwdrivers with replaceable bits will '''++not++''' fit into the hole. InsteadInstead, use a conventional screwdriver that fits.
