Traduction de l’étape 1
Étape 1
Remove the four 12.2mm screws using the Phillips screw driver.
The motors and gear box should now slide out. As you take it out, the metal spring band as well as the track for the wheel gear will also slide off.
When you have separated these parts, you can set them aside until reassembly.
