Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 10 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight. The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
  • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
Fermez le robinet d'arrêt sous les toilettes en le tournant dans le sens des aiguilles d'une montre jusqu'à ce qu'il soit bien serré.
L'apparence du robinet diffère selon les WC, mais la manipulation reste la même.
-[* black] Shut off the stop valve underneath the toilet by turning it clockwise until it becomes tight.
-[* icon_note] The appearance of this valve may differ from toilet to toilet, but most operate the same.
+[* black] Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
+[* icon_note] The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
