Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 25 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Slide the pick along the bottom edge of the phone to slice through the adhesive securing the rear glass. Afterward, it may help to leave the pick in place and grab a second pick as you proceed to the next step. Leaving the pick inserted can help prevent the glue you just separated from re-adhering.
  • Slide the pick along the bottom edge of the phone to slice through the adhesive securing the rear glass.
  • Afterward, it may help to leave the pick in place and grab a second pick as you proceed to the next step. Leaving the pick inserted can help prevent the glue you just separated from re-adhering.
  • Re-heat the rear glass as needed to prevent the glue from cooling and hardening.
Au cours des prochaines étapes, un médiator sera nécessaire pour séparer la vitre arrière du châssis central. Si l'adhésif reste trop collant, n'hésitez pas à le chauffer à nouveau avec l'iOpener.
Avec la ventouse, appuyez au milieu de la vitre pendant que vous soulevez le bord inférieur en faisant pivoter votre poignet.
[* icon_note] The following steps involve using an openingblack] Slide the pick to separatealong the rear panel frombottom edge of the midframe. Ifphone to slice through the adhesive is too strong, reapply heat withsecuring the iOpenerrear glass.
[* black] Usingicon_note] Afterward, it may help to leave the suction cup, apply pressurepick in place and grab a second pick as you proceed to the middle section ofnext step. Leaving the panel while pulling uppick inserted can help prevent the lower edge by pivoting your wristglue you just separated from re-adhering.
[* icon_note] Re-heat the rear glass as needed to prevent the glue from cooling and hardening
