Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 25 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 6
Étape 6
To install new rear glass: Use tweezers to peel away any remaining adhesive from the phone's chassis.
  • To install new rear glass:
  • Use tweezers to peel away any remaining adhesive from the phone's chassis.
  • Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
  • Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
  • If you're reinstalling the old rear glass, or using rear glass without adhesive pre-installed, follow this guide.
À ce stade, la vitre arrière doit être complètement séparée du reste du téléphone, bien que la bande adhésive puisse être fixée sur les deux côtés.
Tirez la vitre arrière vers le haut et enlevez-la complètement.
Suivez ce tutoriel pour réinstaller la vitre arrière.
[* icon_note] At this point, theicon_reminder] To install new rear glass panel should be fully separatedglass:
[* black] Use tweezers to peel away any remaining adhesive
from the body ofphone's chassis.
[* black] Clean
the phone, althoughadhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the adhesive strip may be attached to both sides.
black] PullPeel the adhesive backing off of the new rear panelglass, carefully line up one edge of the glass against the phone chassis, and away to completely separate itfirmly press the glass onto the phone.
[* icon_reminder] Follow [guide|47490|this guide] to reinstallIf you're reinstalling the old rear glassglass, or using rear glass without adhesive pre-installed, follow [guide|47490|this guide|new_window=true].
[* black] Clean
