Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 25 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Once the rear glass is hot to the touch, apply a suction cup near the bottom edge  of the glass. Lift on the suction cup to create a small gap underneath the rear glass, and insert an opening pick into the gap. Optionally, once the pick is inserted, you can add a few drops of isopropyl alcohol into the gap to help weaken the adhesive in the following steps.
  • Once the rear glass is hot to the touch, apply a suction cup near the bottom edge of the glass.
  • Lift on the suction cup to create a small gap underneath the rear glass, and insert an opening pick into the gap.
  • Optionally, once the pick is inserted, you can add a few drops of isopropyl alcohol into the gap to help weaken the adhesive in the following steps.
Posez une ventouse pour les gros travaux sur la moitié inférieure de la vitre arrière.
Accrochez la ventouse en soulevant la poignée rabattable et en mettant le loquet afin de verrouiller les deux poignées ensemble.
[* black] AttachOnce the rear glass is hot to the touch, apply a heavy-duty suction cup tonear the lower half ofbottom edge of the rear glass panelglass.
[* black] SecureLift on the suction cup by raisingto create a small gap underneath the hinged handlerear glass, and flippinginsert an opening pick into the latchgap.
[* icon_note] Optionally, once the pick is inserted, you can add a few drops of isopropyl alcohol into the gap
to clamp both handleshelp weaken the adhesive in placethe following steps.
