Aller au contenu principal
Anglais
Français
Traduction de l’étape 5
Étape 5
Wrap the neutral wire around the neutral screw. Tighten the screw to secure the wire. Remember the neutral wire is the wire with raised ribbing on the coating. Wrap the hot wire around the brass screw. Tighten the screw to secure the wire.
  • Wrap the neutral wire around the neutral screw. Tighten the screw to secure the wire.
  • Remember the neutral wire is the wire with raised ribbing on the coating.
  • Wrap the hot wire around the brass screw. Tighten the screw to secure the wire.
  • The hot wire has a smooth coating.
Enroulez le fil neutre autour de la vis neutre. Serrez la vis pour fixer le fil.
N'oubliez pas que le fil neutre est le fil avec les nervures en relief sur le revêtement.
Enroulez le fil chaud autour de la vis en laiton. Serrez la vis pour fixer le fil.
Le fil chaud a un revêtement lisse.
