Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 12 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 11
Étape 11
Carefully turn the MacBook over, so that the lower case lays flat. Raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
  • Carefully turn the MacBook over, so that the lower case lays flat.
  • Raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
  • Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
  • It's possible to open the MacBook all the way and lay both sides down flat, but this may damage the flex cables and is not recommended.
Insérez ici votre traduction
