Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Use the Pentalobe screwdriver to remove the two 3.6 mm Pentalobe screws near the dock connector. Use the Pentalobe screwdriver to remove the two 3.6 mm Pentalobe screws near the dock connector.
  • Use the Pentalobe screwdriver to remove the two 3.6 mm Pentalobe screws near the dock connector.
A l'aide du tournevis Pentalobe, retirez les deux vis Pentalobe de 3,6 mm près du connecteur de dock.
Evitez d'utiliser le tournevis Pentalobe 5 points trop souvent car il risque d'endommager les vis.
[* red] Use the Pentalobe screwdriver to remove the two 3.6 mm Pentalobe screws near the dock connector.
[* icon_caution] The 5-Point Pentalobe screwdriver should only be used a limited number of times because it has the potential to strip the screws.
