Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 12
Étape 12
If using liquid adhesive remover, apply a few more drops under each of the final two, middle cells. It may help to elevate one side of your MacBook Pro a few inches so that the adhesive remover flows in the correct direction, underneath the battery cells. You can use a sturdy book or foam block to prop up one side of your MacBook Pro while you work. Allow 2-3 minutes for the adhesive remover to penetrate before you continue.
  • If using liquid adhesive remover, apply a few more drops under each of the final two, middle cells.
  • It may help to elevate one side of your MacBook Pro a few inches so that the adhesive remover flows in the correct direction, underneath the battery cells. You can use a sturdy book or foam block to prop up one side of your MacBook Pro while you work.
  • Allow 2-3 minutes for the adhesive remover to penetrate before you continue.
  • Gently folding the right-most battery cells out of the way, insert a plastic card under the right center cell.
  • Push the card in about half of its length to cut the adhesive holding the battery cell to the case.
  • Be sure to avoid the trackpad control board. Aim the card up toward the logic board, where the adhesive is.
  • Leave the card in place to keep the adhesive from re-sealing.
Si vous utilisez le dissolvant liquide, appliquez quelques gouttes supplémentaires sous chacune des deux dernières cellules centrales.
Il peut être utile de surélever un côté de votre MacBook Pro de quelques centimètres afin que le dissolvant coule dans la bonne direction, sous les cellules de batterie. Prenez un livre stable ou un bloc de mousse pour soutenir votre Mac pendant que vous travaillez.
Attendez 2 à 3 minutes que le dissolvant pénètre avant de continuer.
Repliez délicatement les deux cellules de droite et insérez une carte en plastique sous la cellule au milieu à droite.
Insérez-y environ la moitié de la carte en plastique pour faire céder l'adhésif collant la cellule au boîtier.
Veillez à éviter la carte de contrôle du pavé tactile. Travaillez plus en direction de la carte mère, là où se trouve l'adhésif.
Laissez la carte en plastique pour empêcher l'adhésif de recoller.
