Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
Gently pull the front casing from the camera. The following items will either fall off or will be loose: the strap base, the gray rubber cover labeled "Digital A/V Out", and the black rubber piece over the view finder. Remove the memory card cover by sliding down the CF open button and moving the pin.
  • Gently pull the front casing from the camera.
  • The following items will either fall off or will be loose: the strap base, the gray rubber cover labeled "Digital A/V Out", and the black rubber piece over the view finder.
  • Remove the memory card cover by sliding down the CF open button and moving the pin.
Insérez ici votre traduction
