Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 17 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 6
Étape 6
Slide the pick along the edge of the display, towards the headphone jack. If there is still a considerable amount of resistance when sliding the opening pick, repeat the iOpener heating procedure and apply additional heat. Be careful not to let the opening pick slide between the fused LCD and front panel, as doing so can permanently damage the display.
  • Slide the pick along the edge of the display, towards the headphone jack.
  • If there is still a considerable amount of resistance when sliding the opening pick, repeat the iOpener heating procedure and apply additional heat.
  • Be careful not to let the opening pick slide between the fused LCD and front panel, as doing so can permanently damage the display.
  • A good rule of thumb is to never insert the opening pick more than a quarter inch (6 mm) into the iPad.
Faites glisser le médiator en plastique le long du bord de l'écran, vers la prise casque.
Si le médiator rencontre encore beaucoup de résistance, répétez la procédure de chauffage avec l'iOpener et et chauffez plus.
Veillez à ne pas faire glisser le médiator entre l'écran LCD et le panneau frontal fusionnés, cela pourrait endommager définitivement l'écran.
En règle générale, n'insérez jamais le médiator sur plus d'un demi-centimètre dans l'iPad.
[* black] Slide the pick along the edge of the display, towards the headphone jack.
[* black] If there is still a considerable amount of resistance when sliding the opening pick, repeat the iOpener heating procedure and apply additional heat.
[* icon_caution] Be careful not to let the opening pick slide between the fused LCD and front panel, as doing so can permanently damage the display.
[* icon_note] A good rule of thumb is to never insert the opening pick more than a quarter inch (6 mm) into the iPad.
