Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 7
Étape 7
Remove the card from the bottom of the battery and slide it between the battery and rear case,  along the side and underneath the seam where the two battery cells meet. Push the card as far underneath the battery as you can.
  • Remove the card from the bottom of the battery and slide it between the battery and rear case, along the side and underneath the seam where the two battery cells meet.
  • Push the card as far underneath the battery as you can.
Retirez la carte du bas de la batterie et glissez-la entre la batterie et la coque arrière, le long du côté et sous la jointure entre les deux cellules de batterie.
Poussez la carte aussi loin que possible sous la batterie.
