Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 36 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Remove the following 3 screws from the rear wall of the battery compartment:
  • Remove the following 3 screws from the rear wall of the battery compartment:
  • Two 3 mm Phillips #00. (A1181 has three 3 mm screws and one 4 mm.)
  • One 4 mm Phillips #00 on the right side.
  • When reinstalling these screws, press gently on the lower case to line up the screw holes.
  • These screws easily strip, so be careful while taking these particular screws out.
Retirez les 3 vis suivantes de la paroi arrière du compartiment de la batterie :
Deux vis cruciformes #00 3 mm (A1181 a trois vis de 3 mm et une de 4 mm.)
Une vis cruciforme #00 de 4 mm du côté droit.
Quand vous revissez ces vis, appuyez doucement sur le boîtier inférieur pour aligner les trous des vis.
[* black] Remove the following 3 screws from the rear wall of the battery compartment:
[* red] Two 3 mm Phillips #00. (A1181 has three 3 mm screws and one 4 mm.)
[* orange] One 4 mm Phillips #00 on the right side.
[* icon_reminder] When reinstalling these screws, press gently on the lower case to line up the screw holes.
[* icon_note] These screws easily strip, so be careful while taking these particular screws out.
