Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 5
Étape 5
Only adjust it enough to reliably read games and music CDs again. If overdone, the laser can physically "burn" your games or the laser will burn out! Consider anything less then a 80-90% read rate a failure. These are hard to reliably recover. Before starting, mark the original adjustment point and write down the factory setting as tested. It will be difficult to take it back to stock without this information.
Adjust the motor trimpot
  • Only adjust it enough to reliably read games and music CDs again. If overdone, the laser can physically "burn" your games or the laser will burn out!
  • Consider anything less then a 80-90% read rate a failure. These are hard to reliably recover.
  • Before starting, mark the original adjustment point and write down the factory setting as tested. It will be difficult to take it back to stock without this information.
  • Adjust the trimpot incrementally using a Phillips PH1 or other compatible bit. Do this until the laser is reliable and consistently reads games. Test the system to see if it is satisfactory.
Insérez ici votre traduction
