Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 12 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 6
Étape 6
Use your fingernail or the flat edge of a spudger to carefully flip up the upper LCD ribbon cable retaining flap. Make sure you are flipping up the retaining flap, not the socket itself.
  • Use your fingernail or the flat edge of a spudger to carefully flip up the upper LCD ribbon cable retaining flap.
  • Make sure you are flipping up the retaining flap, not the socket itself.
  • Pull the motherboard away from the DS Lite to separate the upper LCD ribbon cable from its socket on the motherboard.
  • Remove the motherboard from the DS Lite.
  • Now you may open the retaining flap for the lower LCD screen in the same way and separate the lower LCD screen from the motherboard.
Insérez ici votre traduction
