Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 17 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Remove the cover from the Game Pak slot before continuing. Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite. Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
  • Remove the cover from the Game Pak slot before continuing.
  • Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite.
  • Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
  • Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
Insérez le bout plat d'une spatule entre les parties inférieure et supérieure de la coque de la DS Lite.
Faites délicatement glisser la spatule le long du bord droit de la DS Lite pour créer une ouverture.
Continuez à faire glisser la spatule le long de l'arrière de la DS Lite jusqu'à ce que les parties inférieure et supérieure se séparent.
+[* icon_note] Remove the cover from the Game Pak slot before continuing.
[* black] Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite.
[* black] Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
[* black] Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
