Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 4
Étape 4
Remove the circuit board by prying it out with a spudger. Remove the flashbulb from its place. When taking out the flash bulb, be sure to carefully remove the wire taped to the back of the bulb (as shown in the second image). Gently separate the tape and the wire.
  • Remove the circuit board by prying it out with a spudger.
  • Remove the flashbulb from its place.
  • When taking out the flash bulb, be sure to carefully remove the wire taped to the back of the bulb (as shown in the second image). Gently separate the tape and the wire.
Retirez le circuit imprimé en le soulevant avec un spudger.
Retirez l'ampoule de son emplacement.
Lorsque vous retirez l'ampoule du flash, assurez-vous de retirer soigneusement le fil collé à l'arrière de l'ampoule (comme indiqué sur la deuxième image). Séparez doucement la bande et le fil.
