Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 16 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Pull up on the exposed clear plastic tab to peel the battery off the adhesive securing it to the iPhone. If the tab breaks before the battery is freed, carefully slide a spudger under the battery tab to release the adhesive. Prying in other places may cause damage.
  • Pull up on the exposed clear plastic tab to peel the battery off the adhesive securing it to the iPhone.
  • If the tab breaks before the battery is freed, carefully slide a spudger under the battery tab to release the adhesive. Prying in other places may cause damage.
  • Remove the battery.
  • If your replacement battery came in a plastic sleeve, remove it before installation by pulling it away from the the ribbon cable.
  • Before reassembly, clean metal-to-metal contact points with a de-greaser such as windex. The oils from your fingers have the potential to cause wireless interference issues.
  • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
Tirez sur la languette en plastique transparent pour décoller la batterie de l'adhésif qui l'attache à l'iPhone.
Si la languette se brise avant que la batterie ne soit dégagée, utilisez une spatule en plastique (spudger) pour décoller l'adhésif. Faites-la passer sous la batterie sans endommager celle-ci.
Retirez la batterie.
Effectuez une réinitialisation matérielle (Hard Reset) après le remontage. Cela peut résoudre des problèmes.
[* black] Pull up on the exposed clear plastic tab to peel the battery off the adhesive securing it to the iPhone.
[* icon_caution] If the tab breaks before the battery is freed, carefully slide a spudger under the battery tab to release the adhesive without puncturing the battery celladhesive. Prying in other places may cause damage.
[* black] Remove the battery.
[* icon_note] If your replacement battery came in a plastic sleeve, remove it before installation by pulling it away from the the ribbon cable.
[* black] Before reassembly, clean metal-to-metal contact points with a de-greaser such as windex. The oils from your fingers have the potential to cause wireless interference issues.
[* black] Perform a [guide|44534|hard reset] after reassembly. This can prevent several issues and simplify troubleshooting.
