Aller au contenu principal
Anglais
Français
Traduction de l’étape 2
Étape 2
Remove the tape that runs along the length of the battery. Lift the retaining flaps of the ZIF connectors on each side of the battery connector. Remove the two ribbon cables that lie across the width of the battery and are connected to the motherboard. Place your finger underneath the ribbon cable and gently lift the cable upwards and off.
  • Remove the tape that runs along the length of the battery.
  • Lift the retaining flaps of the ZIF connectors on each side of the battery connector.
  • Remove the two ribbon cables that lie across the width of the battery and are connected to the motherboard. Place your finger underneath the ribbon cable and gently lift the cable upwards and off.
Décollez la bande le long de la batterie.
Soulevez les clips de maintient des connecteurs ZIF de chaque côté du connecteur de la batterie.
Retirez les deux nappes situées sur la largeur de la batterie et reliées à la carte mère. Placez votre doigt sous la nappe et soulevez et retirez la nappe.
