Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 3
Étape 3
Open the battery cover.
  • Open the battery cover.
  • Remove the four screws inside.
  • One screw is located on the top side of the bottom cover. The remaining three screws are located at the bottom of the battery compartment.
  • Close the battery cover.
Ouvrez le couvercle de la batterie.
Localisez et retirez les quatre vis à l'intérieur.
Une vis est située sur le côté supérieur du capot inférieur. Les trois vis restantes sont situées au bas du compartiment des piles.
Fermez le couvercle de la batterie.
[* black] Open the battery cover.
[* black] Locate and removered] Remove the four screws inside.
[* redicon_note] One screw is located on the top side of the bottom cover. The remaining three screws are located at the bottom of the battery compartment.
[* black] Close the battery cover.
