Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
To remove the sensor assembly, simply peel  off the lens towards the attached ribbon cable. The sensor has ribbon cables running to the motherboard via a black rectangular connector. To remove the sensor, use the spudger to pry up each side, Then, lift the connector straight up from its socket.
  • To remove the sensor assembly, simply peel off the lens towards the attached ribbon cable.
  • The sensor has ribbon cables running to the motherboard via a black rectangular connector.
  • To remove the sensor, use the spudger to pry up each side, Then, lift the connector straight up from its socket.
  • With the old camera sensor assembly removed, you can now replace it with a new sensor.
Insérez ici votre traduction
