Aller au contenu principal
iPod Touch 4th Generation 30 Pin Dock Connector Replacement
Anglais
Français
Traduction de l’étape 4
Étape 4
iPod Touch 4th Generation 30 Pin Dock Connector Replacement: étape 0, image 1 de 2 iPod Touch 4th Generation 30 Pin Dock Connector Replacement: étape 0, image 2 de 2
  • Use extreme caution when handling the front panel assembly, as it is attached to the rest of the Touch by the very delicate digitizer cable.
  • The display data cable is very short and is connected to the logic board near the front facing camera. If it does not disconnect from the logic board while freeing the top edge of the front panel assembly, be sure to disconnect it with a plastic opening tool before rotating the front panel assembly out of the Touch.
  • Carefully pull the top of the front panel assembly away from the adhesive holding it to the Touch, minding the short digitizer cable connecting the two components.
Insérez ici votre traduction
