Aller au contenu principal
iPod Touch 4th Generation 30 Pin Dock Connector Replacement
Anglais
Français
Traduction de l’étape 22
Étape 22
iPod Touch 4th Generation 30 Pin Dock Connector Replacement: étape 0, image 1 de 3 iPod Touch 4th Generation 30 Pin Dock Connector Replacement: étape 0, image 2 de 3 iPod Touch 4th Generation 30 Pin Dock Connector Replacement: étape 0, image 3 de 3
  • Solder all 30 pins back to the logic board.
  • Heat all 30 pins with the tip of the soldering iron.
  • Melt a drop of solder onto the pins and spread it around with the tip of the soldering iron.
  • Repeat until all pins are covered in solder.
  • Make sure solder covers every pin and pushes through to the other side of the logic board.
  • DO NOT push too hard on the pins with the tip of the soldering iron as you could bend the pins.
  • Remove any excess solder with desoldering braid.
Insérez ici votre traduction
