Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
The rubber gasket surrounding the home button is very thin and tears easily. Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button gasket.
  • The rubber gasket surrounding the home button is very thin and tears easily.
  • Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button gasket.
  • Using your fingertip, gently press up on the home button from the front side of the display assembly. Use firm, constant pressure to slowly separate the home button's rubber gasket from the front panel.
En utilisant votre doigt, poussez le bouton home délicatement vers le haut pour continuer à le séparer de l'écran.
Si le bouton home ne se défait pas facilement, continuez de décoller l'adhésif avec un médiator.
[* icon_caution] The rubber gasket surrounding the home button is very thin and tears easily.
[* black] Apply mild heat (with an [product|IF145-198-2|iOpener], heat gun, or hair dryer) to soften the adhesive securing the home button gasket.
black] Using your fingertip, gently pushpress up on the home button assembly up to continue separating it from the front panel.
[* icon_caution] If
side of the display assembly. Use firm, constant pressure to slowly separate the home button does not easily come free, continue separatingbutton's rubber gasket from the adhesive with an opening pickfront panel.
[* icon_caution] If
