Aller au contenu principal
Anglais
Français
Remplacement du panneau frontal de l'iPhone 6s Plus
Informations sur le tutoriel
= Terminé = Incomplet
Front PanelLCD and Digitizer
Plus Front Panel LCD and Digitizer Replacement
    Use this guide to replace a cracked or broken screen inFor an iPhone 6s Plus. This includes removing the front-facing camera and sensor assembly, display EMI shield, easier repair, use our [product|IF315-038|fix kit|new_window=true] and home button assembly—all of which should be transferred follow [guide|55423|this shorter guide] to your new front panel. To replace the your iPhone’s entire display assembly instead, follow [https://www.ifixit.com/Guide/iPhone+6s+Plus+Display+Assembly+Replacement/55423|this much shorter guide]. screen. [ … ] Please note:For more advanced fixers, this guide will help you replace ''only'' the iPhone 6s Plus LCD and digitizer assembly (a.k.a. the bare “front panel”). This requires you to transfer several components from your original screen to the new one before installing it—including the front-facing camera, earpiece speaker, LCD shield plate, and home button assembly. [ ] For all screen/display repairs, it's important to transfer the original home button onto the new display in order for Touch ID (fingerprint scanning) to function. [ … ] '''You can also reference this guide to replace the following parts:''' [ … ] * Earpiece speaker mesh * [https://www.ifixit.com/Guide/iPhone+6s+Plus+Front+Panel+Replacement/50676#s112208 | LCD [guide|50676|LCD shield plate] plate|stepid=112208] * LCD shield plate sticker
      Décrivez la pièce ou le composant spécifique de ce device sur lequel vous êtes en train de travailler. Par ex : batterie
      Créer un titre.
      Ce résumé en 1-2 phrases brèves apparaîtra dans les résultats de recherche.
      Communiquez des informations de base avant que le lecteur ne se plonge dans le tutoriel.
      Étapes du tutoriel
      Étape 1
      Il ne reste que le panneau frontal.
