Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel qui comprend cette étape.
Anglais
Français
Traduction de l’étape 6
Étape 6
Insert an opening pick under the Lightning connector flex cable and slowly slice through the adhesive holding the cable to the rear case. Insert an opening pick under the Lightning connector flex cable and slowly slice through the adhesive holding the cable to the rear case. Insert an opening pick under the Lightning connector flex cable and slowly slice through the adhesive holding the cable to the rear case.
  • Insert an opening pick under the Lightning connector flex cable and slowly slice through the adhesive holding the cable to the rear case.
Insérez un médiator entre le support de mise à terre supérieur droit de la nappe et la coque arrière et commencez à les séparer.
[* black] Insert an opening pick betweenunder the Lightning connector flex cable's upper right grounding bracketcable and slowly slice through the rear caseadhesive holding the cable to begin separating the tworear case.
