Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel qui comprend cette étape.
Anglais
Français
Traduction de l’étape 10
Étape 10
Remove the Lightning connector assembly. If your replacement part did not come with a headphone jack gasket, use tweezers to remove the gasket from the old part and transfer it to the replacement part. Before re-installation, use a spudger to scour any remaining adhesive residue from the rear case. You can use high concentration isopropyl alcohol to help with the process.
  • Remove the Lightning connector assembly.
  • If your replacement part did not come with a headphone jack gasket, use tweezers to remove the gasket from the old part and transfer it to the replacement part.
  • Before re-installation, use a spudger to scour any remaining adhesive residue from the rear case. You can use high concentration isopropyl alcohol to help with the process.
Avec l'extrémité pointue d'une spatule (spudger), poussez la prise Jack de 3,5 mm hors de son emplacement dans la coque arrière.
[* black] UseRemove the pointed tip ofLightning connector assembly.
[* icon_note] If your replacement part did not come with
a spudger[https://d3nevzfk7ii3be.cloudfront.net/igi/XBrYVHBxXx3UmHMn|headphone jack gasket|new_window=true], use tweezers to nudgeremove the 3.5 mm headphone jackgasket from the old part and transfer it to the replacement part.
[* icon_reminder] Before re-installation, use a spudger to scour any remaining adhesive residue
from its housing in the rear case. You can use high concentration isopropyl alcohol to help with the process.
