Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
If you successfully removed all three adhesive strips, move on to the next step. Otherwise, you will need to pry the battery from the rear case. Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or  hair dryer.
  • If you successfully removed all three adhesive strips, move on to the next step. Otherwise, you will need to pry the battery from the rear case.
  • Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or hair dryer.
  • After about a minute, flip the phone over and use a plastic card to break up any remaining adhesive behind the battery.
  • Do not insert your card in the area between the volume down (-) button and the top edge of the battery, or you may damage the volume control cable lying underneath.
  • Do not pry against the logic board or you may damage the phone.
  • Keep the card as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals or catch fire. Do not use any sharp tools to pry at the battery.
  • Alternatively, a piece of dental floss may be used to separate the battery from the rear case. A stronger alternative to dental floss is an unwound guitar string, such as a 0.009 E string from a 12-string set.
  • Thread the floss or string behind the upper battery corners, bring the ends together, wrap them around a folded cloth, and pull evenly.
Si vous avez réussi d'enlever les trois bandes adhésives, passez à l'étape suivante. Sinon il faut enlever la batterie du boîtier arrière.
Préparez un iOpener et appliquez-le sur l'extérieur du boîtier arrière directement au-dessus de la batterie. Alternativement, vous pouvez utiliser une pistolet à air chaud ou un sèche-cheveux
Après environ une minute, retournez le téléphone et décollez tout résidu d'adhésif derrière la batterie avec une carte en plastique.
N'insérez pas la carte du côté droit, car vous risqueriez d'endommager la carte mère. Veillez également à ne pas tordre la batterie, ceci peut la ponctionner et dégager des produits chimiques toxiques.
Ne faites pas levier contre la carte mère, car vous risqueriez d'endommager le téléphone.
Gardez la carte aussi plate que possible pour éviter de plier la batterie, ce qui peut l'endommager et laisser s'échapper des produits chimiques dangereux ou même la mettre en feu. N'utilisez pas d'outils tranchants pour faire levier sur la batterie.
Alternativement, un morceau de fil dentaire peut être utilisé pour séparer la batterie de la coque arrière. Une alternative plus forte que le fil dentaire est une corde de guitare déroulée, par exemple la corde de 0,009 E à venant d'un jeu de 12 cordes.
Enfilez le fil dentaire ou la corde de guitare derrière les coins supérieurs de la batterie, rapprochez les extrémités, enveloppez-les autour d'un chiffon plié et tirez de façon constante.
