Aller au contenu principal
Anglais
Français
Traduction de l’étape 1
Étape 1
Detach the Front Camera ribbon cable  located on the top right corner of the back of the phone by gently lifting it up with a plastic opening tool. Remove the front camera. Be careful when removing the cables and  pulling out the front camera to avoid tearing the attached cable. Be careful when removing the cables and  pulling out the front camera to avoid tearing the attached cable.
  • Detach the Front Camera ribbon cable located on the top right corner of the back of the phone by gently lifting it up with a plastic opening tool. Remove the front camera.
  • Be careful when removing the cables and pulling out the front camera to avoid tearing the attached cable.
Détachez la nappe de la caméra frontale, située dans le coin supérieur droit, en la soulevant délicatement avec un outil d'ouverture en plastique. Enlevez la caméra frontale.
Faites attention en retirant les nappes et la caméra frontale, pour éviter de déchirer les nappes.
