Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Press the small suction cup just above the home button. While lifting up on the suction cup insert an opening pick into the crevice between the screen and back casing to pry the screen off carefully. Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
  • Press the small suction cup just above the home button.
  • While lifting up on the suction cup insert an opening pick into the crevice between the screen and back casing to pry the screen off carefully.
  • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
  • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone freeing the two halves of the phone.
Insérez ici votre traduction
