Aller au contenu principal
Anglais
Français
Traduction de l’étape 7
Étape 7
Use a spudger, or other thin object, to remove the capacitor from the housing. (Image 2) To remove the red and yellow wires connected to the capacitor, use a soldering iron to heat up the solder and a vacuum to suck up the solder. Any other methods you know of will also work.
  • Use a spudger, or other thin object, to remove the capacitor from the housing. (Image 2)
  • To remove the red and yellow wires connected to the capacitor, use a soldering iron to heat up the solder and a vacuum to suck up the solder. Any other methods you know of will also work.
  • Take the capacitor to you local electronics store or order another capacitor online by reading the capacity off of the side of the capacitor. It should be in microFarads (µF).
  • Once you have a new capacitor, solder on the red and yellow wires to the same place as the old capacitor.
Insérez ici votre traduction
