Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
The plastic frame is clipped inside the steel body with four clips, two each on the left and the right side of the watch, near the corners. You can stick a small screwdriver into the cutouts right above the clips and gently lever the plastic frame up, corner by corner. Once the clips are released, use a pair of tweezers to grab onto the black plastic frame and remove the internal hardware.
  • The plastic frame is clipped inside the steel body with four clips, two each on the left and the right side of the watch, near the corners. You can stick a small screwdriver into the cutouts right above the clips and gently lever the plastic frame up, corner by corner.
  • Once the clips are released, use a pair of tweezers to grab onto the black plastic frame and remove the internal hardware.
  • Adhesive on the back side of the battery holds the internal components to the front case.
  • Use tweezers or a plastic opening tool to disconnect the ribbon cable from the motherboard.
Insérez ici votre traduction
