Aller au contenu principal
Anglais
Français
Traduction de l’étape 4
Étape 4
Remove the hinge plate screws (5.52 x 3.43 mm) with the PH 2 screw driver. Then lift out the hinge mount. Then lift out the hinge mount.
  • Remove the hinge plate screws (5.52 x 3.43 mm) with the PH 2 screw driver.
  • Then lift out the hinge mount.
Retirez les vis de la plaque de charnière (5,52 x 3,43 mm) à l'aide du tournevis PH 2.
Soulevez ensuite le support de charnière.
